Change the VRF instance as required to view TCP connections information on a specific VRF instance. Not all parameters are configurable on non-default VRFs.
Perform this procedure to view the status of connections that traverse your switch.
- Select TCP/UDP.
- Select the TCP Connections tab.
TCP Connections Field Descriptions
Use the data in the following table to use the TCP Connections tab.
| Name | Description |
| LocalAddressType | Displays the type (IPv6 or IPv4) for the address in the LocalAddress field. |
| LocalAddress | Displays the IPv6 address for the TCP connection. |
| LocalPort | Displays the local port number for the TCP connection. |
| RemAddressType | Displays the type (IPv6 or IPv4) for the remote address of the TCP connection. |
| RemAddress | Displays the IPv6 address for the remote TCP connection. |
| RemPort | Displays the remote port number for the TCP connection. |
| State | Displays an integer that represents the state for the
                                        connection:
| Process | Displays the process ID for the system process associated with the TCP connection. |
